1966 stv valve and r-12 freon charge - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    I am charging my system with r-12. I stopped the charge at 2.6 lbs because there were no sign of bubbles in the sight glass, should I continue to charge until I reach 3.4 lbs? And what does it do for my system to adjust the stv valve(low side) down to 30psi? Need some a/c experts. Thanks, Dutch
  • Douglas L.
    • May 8, 2015
    • 181
    Re: 1966 stv valve and r-12 freon charge
    I'd fill the system to spec and see how well it cools, really the bubble method is more for systems that don't have a exact capacity spec. You can adjust the low side down as low as youd like but if you go too low you'll get evaporator freeze up.
    • Harry L.
      • December 22, 2008
      • 370
      How much of the no-drip insulation should be rapped around the evaporator tube? Can this be an issue if not enough? Dutch
      • Douglas L.
        • May 8, 2015
        • 181
        Are you talking about the sticky tape that goes around the sensing bulb from the expansion valve?
        • Harry L.
          • December 22, 2008
          • 370
          Yes, would you have a pic of the amount of tape that you used on your expansion valve tube? Thanks,Dutch
          • Douglas L.
            • May 8, 2015
            • 181
            Sorry, don't have a A/C car. Just going by past experience, 3-4 wraps should suffice. Hopefully someone else will have a pic for you.
