The 4150 Holley on my '72 continues to leak a small amount of gas. I have replaced the accelerator pump and gasket and tighten the 4 screws. I have also tighten the 4 bolts on both the primary and secondary bowls. The fuel input lines at both the primary and secondary bowls have also been tighten. This corrects the leak problem for a time, but it does return.
I have heard the 4150's do occasionally leak gas. Is this true? One way or another I would like to get to the bottom of this problem. Any thoughts, comments or suggestions will be appreciated.
