Where is oil pan part number? - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    I'm trying to id an BB oil pan I have which I believe is for a full size Chevrolet. Do the oil pan's have part numbers stamped anywhere. Believe it to be a mid 60's 396 pan.
    Jack
    Jack Ottofaro
  • Keith B.
    • September 15, 2014
    • 1600
    Re: Where is oil pan part number?
    there are no numbers stamped on the pan. can you post a picture
    • Mike E.
      • February 28, 1975
      • 5141
      Big block GM replacement pans are the only ones I've seen with stamped part numbers.
        • 43273
        Mike-------
        ...and only some of those have the part number. Most do not.
          • 43273
          Jack
          Jack-------
          A photo would possibly help us ID it. However, if the pan has a side oil drain, it's a non-Corvette oil pan. If it has a rear oil drain, somewhat off-set to one side, the chances are almost certain it's a Corvette oil pan.
          There were several different Corvette big block oil pan part numbers used over the 1965-74 period and one SERVICE-only pan which is still available to this day (GM #14091356). However, there was really very little configurational difference between the pans.
          • Keith B.
            • 1600
            I think there is only minor differences between a A-body oil pan and a B-body pan And later F-body and X-body pans. Pictures would help
