THE TITLE SHOULD READ ALARM RELAY SWITCH INSTEAD OF HORN RELAY. I recently replaced my door ajar switches and installed a new OEM rear alarm keyway, that I got from Pete Lindahl and everything worked great. The alarm sounded when a door or the hood was opened and the horn pulsed as it is supposed to. Then all of a sudden the alarm quit working. When I turn the alarm keyway, I can hear a slight clicking (chirp) sound under the right side of the car where the relay switch is located. The alarm horn is working, I tested it with a battery to make sure. Is it possible the relay switch just went bad? This system wasn't functional for a long time.
