Source for this C1 door screw? - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5141
    At the bottom of the window sash, inside the door, the lower window guide channel (straight, u-shaped) attaches to the sash with two of these screws on each end. They are 8-32, 5/16" in length, with the conical external tooth washer. I didn't find them in any of the catalogs that I have--did I miss them, or do vendors not have them. If the usual vendors don't have them, who does? I know I can get a 3/8" one at the hardware store without the conical washer, and yes, I know that no one will ever see them, but...........
  • Dan B.
    • July 13, 2011
    • 545
    Re: Source for this C1 door screw?
    Mike if you can't find one, you can easily make one. The screw is common, get the right star washer and peen it over using a small socket. I 've done that in the past and it worked fine.
    • Mike M.
      • May 31, 1974
      • 8401
      mike: how many ya need? u going to joplin? i can bring some if so.PS: there is no charge as long as u bring the collection plate too receive them . mike
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11345
        Mike I just got some from Zip. The conical washers are not integrated, so I put a little dum-dum on them so they stay put.
        Rich
        Shop for 2009-2013 Corvette ZR1 Valve Stem Caps (Chrome) from Zip Corvette - your source for C6 Corvette wheels and accessories including valve stem caps.
