Oil Pan Flange - domed bolt holes - NCRS Discussion Boards
  • Peter S.
    • March 28, 2012
    • 327
    This oil pan, as well as every other gasketed surface, leaked like a sieve before teardown. As I prep it for installation, I noticed that the bolt holes are heavily domed from the bolts being torqued down. I can flatten them somewhat going around with regular tip C-clamp. Is this worth the risk? Any other method to flatten out the bolt holes?
    • 43259
    Re: Oil Pan Flange - domed bolt holes
    Peter------
    You must flatten them. I usually do it by placing a block of hardwood under the holes and tapping them flat with a hammer.
    • Peter S.
      • March 28, 2012
      • 327
      A block of wood - I feel a little silly for not thinking of that. Thanks Joe.
      • Leif A.
        • August 31, 1997
        • 3646
        And, then when rebolting, be aware of how tight you bolt up. I usually put all bolts in finger tight and then starting in the middle and working my way out, I tighten until snug and then and additional 1/4 turn.
        Leif
        • Peter S.
          • March 28, 2012
          • 327
          • Domenic T.
            • January 29, 2010
            • 2452
            Peter,
            When tightening as said above, they will loosen as the gasket takes a set. I always do a retighten a few times until the stabilize.
            Most shops/dealerships don't have time to do it that way and only tighten once. Also if using a sealant it is easy to split the gasket at each bolt.
            I usually let the sealant set up before final torque. Everyone has their way of doing it but as Joe said tap each down, best done with the whole side of the pan on the flat surface.
            Dom
              • 43259
              Originally posted by Domenic Tallarita (51287)
              Peter,
              Dom
              Dom-------
              This is another advantage of using the one piece gasket. Each of the bolt holes is fitted with a compression-limiting "ferrule". So, the gasket is compressed by the exact amount required and the amount of torque applied to the bolts is limited. With this type gasket, no re-torque is required.
              • Steve G.
                • November 24, 2014
                • 411
                When I first started working in the trade I wondered why the original OE gaskets stuck like glue to the both sides (on anything, valve covers, water pumps...)with no traces of glue and the joint completely sweat free while gaskets that had been replaced once peeled off the surfaces with ease when torn apart and, if not leaking profusely, at least had a good sweat at the joint. In fact the OE gaskets on the valve covers stuck so tight you would bend the lip of the valve cover trying to pry them off.
                The reason turned out to be an oil free surface. Not just wiped down with a rag soaked in solvent or gasoline (always a bad idea) then dried off with a dry cloth, which was what was usually done in the trade. This left behind traces amounts of solvent or oil which inhibited the gasket's ability to seal.
                It's gotten much easier to get a dry joint with the availability of aerosol brake cleaners. These work remarkably well at lifting the contaminants from the surface. It works best if you actually spray the surface rather than wiping down with a rag saturated in the cleaner. The spray seems to lift stuff out of the "pores". Blow dry with air and keep your oily fingers off of the surfaces.
                Steve
                  • 11678
                  Peter------
                  Agree. I use a ball peen hammer which works very well.
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Joe,
                    I guess I have to move up to the modern tech.
                    Dom
