65 rear spring center bolt - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    what is the torque setting for the center bolt on a 65 std. rear spring ?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 rear spring center bolt
    Bill -- all that's said in the '63 Shop manual, section 4 figures 21 and 22 is "tighten securely" (after assembling the leafs and liners).
    Same words in the '66 shop manual. I'd use up to the torque specified in standard bolt tables for 5/16" fine thread (say 10 ft-lbs). It will probably turn before that. The spring/liner stack should be held together in a C-clamp while tightening center bolt.
    • Bill W.
      • March 1, 1980
      • 2000
      Thanks Wayne
      • Jimmy G.
        • November 1, 1979
        • 977
        it should be redone after the car has been reassembled also
