1973 Kick Panel Questions - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    Removed both kick panels today to check out condition of the birdcage around the body mounts there (btw there was only surface rust), and have now a few questions:
    1) the screw in corner which secures the right kick panel was loose, and I realized there is no screw hole for it. The AIM is not clear. Is there supposed to be a hole in the fiberglass to accept the screw?
    2) There was a thin cardboard like panel behind each kick panel covering the area behind the small ventilation grill holes (not the astro ventilation) it appears to be some kind of thick tar paper board. What is it? Where can I get replacements? How is it secured?
    3) There is a rubber insulation flap at the top edge of the carpets in the front footwells. It lays over the top edge of the carpet. Is this correct, or should the carpet lay over top of the rubberized flap? Everything looks very original and undisturbed. What is that rubber flap btw?
    Thanks so much. Voyage of discovery!
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1973 Kick Panel Questions
    Yes the screw should be screwed into the fiberglass
    Can't say I have ever seen the card board paper[
    The rubber insulation flap goes over the carpet.QUOTE=David Ciaramello (45974);742639]Removed both kick panels today to check out condition of the birdcage around the body mounts there (btw there was only surface rust), and have now a few questions:
    Thanks so much. Voyage of discovery![/QUOTE]
    • David C.
      • June 30, 2006
      • 126
      Thank you Russ, appreciate your response. I don't see a hole in the fiberglass, which is odd. I suppose I will have to drill it, or not worry about it.
      Does anyone else know about those press board / tarred cardboard pieces behind the kick panels?
      • John S.
        • June 15, 2015
        • 508
        David - I realize this is an older thread but I wanted to give you some additional info on your C3 kick panels. I also found the heavy tar paper insulation (brownish color) behind my kick panels. Looks like it was held in place with small amount of adhesive on the vertical sections. I used two small spots of W/S adhesive when I put things back together. Regarding screws in the forward portion of the panel, no screws found in mine and no hole found in the FG behind. I am leaving screws out until someone advises differently.
        1973 L82 M21 4 Speed, very original and well documented driver/survivor
        NW Chapter Member, 2016 Bend Regional Top Flight
        73/74 TIM&JG 3rd Edition Revision Team Member
        • David C.
          • June 30, 2006
          • 126
          Thank you John!
          Dumb question - what is W/S adhesive?
          • John S.
            • June 15, 2015
            • 508
            Sorry, Weatherstrip Adhesive - I used the high tack black stuff from 3m. The world of abbreviations gets carried away sometimes !!
            • Harmon C.
              • August 31, 1994
              • 3228
              You need the kick plate screws for judging but I think most of the screws were never installed. They are very hard to get lined up.
              Lyle
              • Jimmy P.
                • June 24, 2014
                • 1696
                Lyle,
                I notice on some of the kickplates out there for sale that some have a hole for mounting on the lower part of the panel just off from the venting holes. What year/years were these correct for? Thanks.
                Jimmy
                1973 Convertible
                L48,M20,N40
                Mille Miglia Red/Oxblood
                • John S.
                  • June 15, 2015
                  • 508
                  Thanks Lyle, getting the holes drilled into the body so the screws have something to bite into will be the tougher part. This may be interesting.
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    A self drilling and taping screw would make the job easier. I have seen some made that way.
                    Lyle
                    • John S.
                      • June 15, 2015
                      • 508
                      Thanks Lyle, good suggestion. I just think its a little strange to modify the car (albeit an extremely small modification) to match the Judging Manual. I realize we have to have a standard to judge to and it's very difficult to verify what the assembly plant did or didn't do on any given day, it just seems strange to put a new hole in a place it hasn't been for the past 42+ years !!?? The jury is still out on my end, to drill or not to drill ?? Thanks again for the info !!
                      • Harmon C.
                        • August 31, 1994
                        • 3228
                        You could put a screw in the hole and some putty on the back side to hold it in and no hole will be needed. The judge will be happy and no new holes.
                        Lyle
