2004 Corvette, Gas Cap Door Locking Mechanism - NCRS Discussion Boards
  • John L.
    • 102
    Not sure what happened but the Gas Cap Door is not locking and looks like the locking mechanism to the right of the gas cap has broken. Has anyone on the DB experienced such a problem? Also, would someone post a picture of the locking mechanism? Guess I'm off to the Chevy Dealer, thanks.
  • Mike E.
    • June 24, 2012
    • 920
    Re: 2004 Corvette, Gas Cap Door Locking Mechanism
    John,
    I haven't had an issue with mine. Here is a photo from my '01 Z of the latch as installed in the car.
    Mike
    • Tom H.
      • December 1, 1993
      • 3440
      I've had them just stick already. A little spray lube might do the trick if it isn't truly broken.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Paul O.
        • August 31, 1990
        • 1716
        John
        There is a return spring that is most likely broken. Here is a thread on how to repair. Hope it helps.
