1967 Briggs and Stratton Ignition Key Blank - NCRS Discussion Boards
  • Robert M.
    • April 30, 1999
    • 415
    Who sells the hex Briggs and Stratton 1967 ignition key blanks? I have the wrong key but don't want to replace the entire lock assembly. Thanks.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 1967 Briggs and Stratton Ignition Key Blank
    Here you go, Robert...https://www.paragoncorvette.com/p-35...nk-a-code.aspx
    Leif
    • Jaime G.
      • April 1, 1988
      • 480
      Do you want a GM issue key or reproduction?
      If you want the GM issue B&S key contact Pete Lindhal
      He is listed in this forum.
      • Bill W.
        • March 1, 1980
        • 2000
        I know Pete has some 67 NOS GM blanks .
        • Robert M.
          • April 30, 1999
          • 415
          Thanks Jaime, I contacted Peter and he is sending me a GM key blank. Thanks again.
          • Tim G.
            • March 1, 1990
            • 1389
            Pete does good work.
            • James G.
              • May 31, 1976
              • 1556
              He saved our day at FRISCO last October. Had a NOS 67 Switch.
              • Joe R.
                • July 31, 1976
                • 4551
                Does the key blank for the 67's look like these?
                • Gary B.
                  • February 1, 1997
                  • 7053
                  JR[ATTACH=CONFIG]60519[/ATTACH]
                  Joe,
                  I can't see the letter A stamped into the upper end of the key rail. If they don't have that A (nor a C for '68), then they are pre-67 blanks. But I think they are later service replacements because the key ring hole in the knockout appears to me from the non-close-up photo to be the smaller of two possible diameters, and most evidence suggests that '67 (and maybe even '68) and earlier keys came with the larger (9/64"?) diameter hole.
                  Gary
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    Joe - Yes, the '67 ignition & door keys look like the keys in your photo, but they are not '67 "A" code keys as mentioned. The Part Number 3694624 shown on the box is listed in the October 1, 1966 CHEVROLET P & A CATALOG in Group # 2.187 as
                    38-66 ALL, CORVETTE .............. (octagon hd. - w/knock out plug - ignition,door and tire lock) (series 8000-9499).
                    The keys with the smaller key ring hole in the KNOCK OUT were probably manufactured starting some time in calendar year 1968.
                    Pete
