1965 FI Ignition shielding - NCRS Discussion Boards
+ More Options
Posts
  • John M.
    • September 30, 2000
    • 43
    Here in England I have a 1965 FI car with the FI on the car. The car is a non radio car. My question is how much of the shielding should I be looking to fit to the engine. Am I looking to just put enough on for routing the plug wires, i.e. just the two large pieces either side on the block together with the two brackets and rubber grommets either side of the distributor
    Thanks and regards JOHN
  • William C.
    • May 31, 1975
    • 6037
    Re: 1965 FI Ignition shielding
    It is more than just the shielding that is left off if not radio equipped, several grounds and capacators are also not used on a non-readio car. Get an assembly manual and look at the U69 radio section and you will have a complete list of things to look for.
    Bill Clupper #618
    • John M.
      • 43
      William, thank you for that
      Regards John
