1969 Alternator - NCRS Discussion Boards
1969 Alternator
    • 43275
    1969 Alternator
    Here's an interesting piece. I acquired this some time ago and, at this point, have forgotten where. I just found it the other day behind some other things here in my office. It's a 1969 alternator with the six "spoke", open drive end case and the seven fin with flat grounding lug slip ring case. This was the 1969-only configuration. However, this was not a Corvette alternator. Many folks think that the SI series alternator, first used for 1969, was used only on Corvettes for that model year. That's not the way it was, though. There were a few other 1969 GM applications for the SI alternator, although none were for Chevrolet passenger cars.
    This alternator was a GM #1100854 [not for sale]. It was used on 1969 Pontiacs with 61 amp alternator and heated rear window. From what I can find, it was never available in SERVICE. Instead, for SERVICE, the GM #1100825 was specified. The latter is a quite sought-after alternator that was used in PRODUCTION on 1969 Corvettes.
    This particular alternator was manufactured on February 11, 1969. I'm quite sure it's never been rebuilt since the stamped broadcast code is still present and the correct front and rear case halves are intact.
  • Edward B.
    • March 29, 2013
    • 691
    Re: 1969 Alternator
    Joe, when I was searching for one for my car, I did a TON of research and found the following applications to use the SI alternator with the spokes and the cooling fins. Maybe this will help others in the future.
    Ed
    1100825 - 61 Amp - 1969 Corvette (early), 1969 Chevrolet truck (366 or 427), 1969 Firebird 400, 1969 Pontiac
    1100830 - 55 Amp - 1969 Firebird 400
    1100832 - 37 Amp - 1969 Firebird 400
    1100833 - 42 Amp - 1969 Corvette (early), 1969 Chevrolet truck (366 or 427), 1969 Pontiac Firebird
    1100852 - 55 Amp - 1969 Olds 442
    1100853 - 37 Amp - 1969 Olds F85, 1969 Olds 442
    1100859 - 42 Amp - 1969 Corvette
    1100880 - 42 Amp - 1970 Olds F85, 1970 Olds 442
    1100881 - 42 Amp - 1969 Corvette (late)
    1100882 - 61 Amp - 1969 Corvette (late)
    1100884 - 61 Amp - 1969 Corvette (late), 1970 Corvette
    1100890 - 55 Amp - 1970 Olds F85, 1970 Olds 442
    1100897 - 61 Amp - 1970 Chevrolet Truck (366 or 427)
    1100899 - 42 Amp - 1970 Chevrolet Truck (366 or 427)
    1100900 - 42 Amp - 1969 Corvette (late), 1970 Corvette
    1100901 - 42 Amp - 1970 Corvette, 1970 Cadillac Eldorado
    Maybe (needs more research):
    1100908 - 42 Amp - 1970 Cadillac Eldorado
    1100910 - 63 Amp - 1970 Cadillac Eldorado
    • Peter S.
      • March 28, 2012
      • 327
      Re: 1969 Alternator
      Hi Ed,
      What is the star next to the 1100884?
      • Edward B.
        • March 29, 2013
        • 691
        Re: 1969 Alternator
        Oops. That was the one specific to my car I was looking for. I'll edit the post and remove the asterisk.
        Ed
        • Richard K.
          • April 1, 1988
          • 207
          Re: 1969 Alternator
          Ed,
          You might want to add to your research data:
          1100900, which, in addition to being used on the 1970 Corvette was used sporadically in late 1969. I have one on my '69 built the first week of December 1969. It's dated 9L6. These have now been recognized in the '68-'69 Judging Guide:
          "**1970 alternator is seen sporadically on original 1969 cars from July 1969 to the end of 1969 production".
            • 43275
            Re: 1969 Alternator
            Originally posted by Richard Kossum (12684)
            Ed,
            Richard------
            Is the slip ring (rear) case half of your 1100900 exactly the same as the one I pictured above?
            • Edward B.
              • March 29, 2013
              • 691
              Re: 1969 Alternator
              Thanks Richard. I edited the above to add that info.
              Ed
