1971 Taillight Housing - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 481
    Just wondering if anyone has a method for replacing the mounting studs in the taillight housing. It appears they are pressed in somehow.
    thanks
    Sheldon
    • 6956
    Re: 1971 Taillight Housing
    Sheldon, I has one that was broken on my 72 and I just used a 1/-4 20 hex head bolt and ground down the head to look correct and JB welded into place.
      • 3418
      Hi Sheldon,
      I did something similar with a stud on one of my housings.
      Fortunately, because of the location of the studs (not under the lens' gasket) the head of the bolt doesn't need to be completely flat.
      • Harmon C.
        • August 31, 1994
        • 3228
        If you drill them out to 13/64 and tap them 1/4-20 lock tight will hold them in.
        Lyle
