70-72 Convertible w/ ac Interior - NCRS Discussion Boards
    • 3418
    Hi,
    70-72 convertibles with a/c used a small 'cover' (3954504) that was attached to the right side shifter console extension 'panel' (3954502) using 2 screws. UPC C60, Sheet A5, Item 9.
    Is this the same part as used for 69 convertibles with a/c?
    Photo from a 69 convertible w/ ac Bowtie car.
  • Edward B.
    • March 29, 2013
    • 691
    Re: 70-72 Convertible w/ ac Interior
    Yep. Sure was Alan, but part number 3954504 wasn't for the part itself but for the chart showing the different part numbers for each color.
    Ed
      • 3418
      Hi Ed,
      Thanks very much for the information.
      I appreciate it.
      • John C.
        • January 1, 2005
        • 616
        In 1969 the cover was used on more convertibles then just those with A/C. Early in the model year it was used on all convertibles to cover up a stiffening brace. Later in the model year the brace configuration was changed on non-A/C cars and the cover was no longer needed and removed.
        John
          • 3418
          Hi John,
          Thanks!
          It appears from looking at the 71 AIM that the cover was used just on a/c convertibles as you suggest.
          So I value your information.
