C2 side pipe installation passenger side with or without heat-riser (or spacer) ? - NCRS Discussion Boards
  • Ruud Z.
    • April 30, 2006
    • 69
    I was wondering if sidepipes still require to install the heat-riser (or simular spacer) on the passenger side of a C2.
    It seems bot side pipes l and r are the same in length and have the same curves. Thanks. Ruud.
  • Bill M.
    • 1328
    Re: C2 side pipe installation passenger side with or without heat-riser (or spacer) ?
    Ruud
    you need the heat riser. The riser seems to fail every couple of years so if you are not having your car judged just hollow an old one out.
    • Dennis B.
      • May 31, 2004
      • 175
      My '66 required the heat riser for the passenger pipe to fit correctly.
      • Stuart F.
        • August 31, 1996
        • 4676
        You didn't state BB or SB. If the latter, and it's not to be judged, you can use an F.I. Spacer. It has flats inside, but they can be ground out for nice big round opening.
        Stu Fox
