1962 Borg Warner T-10 Schematic - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Anyone happen to have an exploded view of a October of 1961 built
    Borg Warner T-10 that I can get a copy of?
    thanks
  • Donald H.
    • November 2, 2009
    • 2580
    Re: 1962 Borg Warner T-10 Schematic
    Here's a document I found when I was rebuilding my T10. Mine was a 1960 and had a cast iron main case and you 62 would have an aluminum main case. And difference castings number on the cases, but as far as I know the internals are the same.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • 6940
      David, you can also Google Borg Warner T-10 and there is alot if info and there is even one of a step by step overhaul.
      • Domenic T.
        • January 29, 2010
        • 2452
        David,
        If I remember right, it was in the 58 book when they had the cast iron case. The later manuals had them as a supplement. I would think they would have a good view when the went to the aluminum case.
        I remember using the 58 manual when I did them but that won't help if you don't have one. Someone here with a good camera should be able to get a good pic.
        I do have the 58 manual at the shop and also the 59. The 59 was only a supplement of the 58.
        Dom
        • Joe R.
          • May 31, 2006
          • 1822
          Hi David,
          There is an article in this newsletter that may help you, starting on page 3:
          Joe
          • Loren L.
            • April 30, 1976
            • 4104
            There will be an exploded view in the illustrations part of every 1958 - mid 60s parts book.
            • David H.
              • November 11, 2009
              • 777
              Thank you everyone for your very helpful suggestions.
              Very much appreciated.
