1956 Thermostat Housing...painted or plated? - NCRS Discussion Boards
  • John C.
    • July 11, 2011
    • 122
    Hi,
    The 6th edition JG states the 1956 Corvette aluminum intakes used the 3705018 CAD plated cast iron thermostat housing.
    Experts are divided....it was painted argent silver, no it wasn't....it was CAD plated!
    Jeeze, has anyone ever seen a CAD plated housing....just asking!
    I'm trying to get it correct!
    Thanks!
    John
  • Mike M.
    • May 31, 1974
    • 8399
    Re: 1956 Thermostat Housing...painted or plated?
    i've never seen a cad plated housing but i've only glass beaded several and no sign of cad on them. i sent a couple of the housings out for cad plating on my pair of 57 FI's. judged well. again, not sure they were cad plated but i went along with the 56-7 JM.. mike
    • John C.
      • July 11, 2011
      • 122
      Hi Mike,
      Hmmm, your observation is very interesting....no sign of cad on them. I would like to go along with the program, but.....?
      In any case, I'm having trouble even finding a place in CA that will CAD plate them....any suggestions?
      Thanks man!
      John
      • Mark S.
        • July 31, 1983
        • 660
        Mine were painted and not cad plated. Also, some 56 passenger cars used the same housing; and I have seen them not cad plated. Some of those were painted.
        • Mike M.
          • May 31, 1974
          • 8399
          i send all pieces needing cad to dave cardina in ohio. send me a PM and i'll provide dave's contact info. mike
          • John C.
            • July 11, 2011
            • 122
            Hi Mark,
            Thank you for that! Have you ever seen a cad plated housing?
            Thanks again!
            John
            • John C.
              • July 11, 2011
              • 122
              PM sent, thank you!
              John
                • 43246
                Originally posted by John Coupens (53567)
                Hi Mike,
                Thanks man!
                John
                John-----
                If you want to have the housing plated, have it zinc plated. No one can visually tell the difference between zinc and cadmium. Of course, you will want dull zinc just as you would want "dull" cadmium (cadmium or zinc can be dull or shiny).
                Electroplating Specialties (EPS) in Hayward, CA does both cad and zinc plating (or, at least, used to do so). However, as with virtually all platers, there is a minimum charge. So, if you have 1 piece or 100 pieces, the charge will be the same. Consequently, having just 1 piece plated will be VERY costly.
                • John C.
                  • July 11, 2011
                  • 122
                  John-----
                  Hi Joe,
                  Ok, great....Hayward is relatively local.
                  I actually do have an additional item to plate, the cresent shaped ignition wire shields I received were terrible:
                  Anyway, it just seems that there were a large number of painted housings on factory cars....I wonder why they are not acceptable as well?
                  Thanks so much!
                  John
                  • Mark S.
                    • July 31, 1983
                    • 660
                    John: I have not seen a known original to be plated. Mark
                      • 43246
                      Hi Joe,
                      [ATTACH=CONFIG]60206[/ATTACH]
                      Thanks so much!
                      John
                      John------
                      Personally, I've never seen any GM thermostat housing that was plated. The only type I've seen used on aluminum manifolds were painted with dull aluminum paint if cast iron and natural aluminum if aluminum.
                      I've got to admit, though, that may familiarity with this particular C1 thermostat housing is minimal.
                      • John C.
                        • July 11, 2011
                        • 122
                        John------
                        Ok Joe...thanks so much!
                        John
                        • John C.
                          • July 11, 2011
                          • 122
                          Thank you Mark! It seems to be a very rare/elusive original part.
                          John
                          • John D.
                            • December 1, 1979
                            • 5507
                            Send your parts directly to the plater if you like. Beringer's Plating in Akron Ohio They do wonderful cadmium plating but expect to pay big bucks. Used to be in the old days (5 years ago) cad plating was not a big expense in restorations. Today it is. The good thing about Beringer's is they have never lost a part for me. Been using them now for an eon. I would rather play for high quality plating than go elsewhere where you can get a bucket of parts done for less money and the quality of the plating is not up to par.
                            They have a website but I don't have a link. Located 1211 DeValera Ave., Akron, OH 44310 330-633-8409
                            How to get the most bang for your buck when having parts cadmium plating. Get a ton of parts plated at the same time. The more you get the best value you will receive. Don't think about sending a small box of parts/trinkets. You can but expect to pay. John D
                            • John D.
                              • December 1, 1979
                              • 5507
                              I have heard about cad plated water outlets but so far have never seen one. That doesn't mean anything though. But I have been into water outlets for at least 50 years and haver yet to see one plated.
                              Might be a good idea though if it will pass judging.
                              Or just use Krylon Dull Aluminum after first blasting the part. JD
