53-55 6 cyl. Valve Cover Gasket Material? - NCRS Discussion Boards
  • Eric F.
    • June 30, 2003
    • 319
    The TIMJG mentions gaskets in the mechanical section but I couldn't find anywhere in the manual where it specifies the gaskets composition; I suspect it was cork. Does anyone know the color and type of material (cork, rubber) used for an original valve cover gasket?
    P.S. For what it's worth this valve cover is one of the chromed ones.
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 53-55 6 cyl. Valve Cover Gasket Material?
    tan cork. mike
    • Eric F.
      • June 30, 2003
      • 319
      Thanks Mike. I found they currently make two thicknesses in cork- 5/32" and 7/32". I think the thin one was original size. Do you know for sure?
      • Mike M.
        • May 31, 1974
        • 8400
        not sure but i'd go with the thin one. the c-1 and c-2 sbc's used a thin one whereas the napa type gaskets are too thick. mike
        • Gary H.
          • June 30, 1980
          • 155
          If you are looking for a 53 gasket:
          Chevs of the 40s
          p/n 3694248
          They were $10 last year! BTW, they are thick!
            • 43248
            Eric------
            Here's the deal according to GM and it's kind of interesting.
            1953 Corvettes used gasket GM #3694248. This gasket was cork and 3/16" thick. They may also have used gasket GM #3696781. This gasket was 1/4" thick.
            1954-55 (6 cyl) Corvettes used gasket GM #3708648. This gasket was cork and 5/32" thick. They may also have used gasket GM #3708646. This gasket was cork and 1/4" thick.
            Later, the GM #3708648 became the SERVICE gasket for all 1953-55 6 cylinder Corvettes.
            • Troy P.
              • February 1, 1989
              • 1284
              No better info than that!
              • Eric F.
                • June 30, 2003
                • 319
                Thanks everyone for the information. Especially Joe; you're right that is interesting. For those who are interested in purchasing the correct gaskets I offer my findings. After searching the regular corvette suppliers I checked with a couple of the big name auto parts stores and found Felpro makes the correct cork replacement gaskets in both thicknesses Here are the part numbers: FEL-PRO Part # VS50189C (5/32" thick)
                FEL-PRO Part # VS50190C (7/32" thick); the prices ranged from $5.24 to $11.99.
                Thanks again to each of you for sharing your knowledge.
