1966 tele steering - NCRS Discussion Boards
1966 tele steering
  • John N.
    • April 9, 2012
    • 17
    1966 tele steering
    Need to replace turn signal switch on a telescoping steering column. Can any one tell me if the black sleeve that the wires run thru actually moves in and out when the steering wheel is telescoped in and out? Right now when the wheel is completely pulled out the 7 wire loom is totally exposed, that doesn't same aesthetically correct.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1966 tele steering
    Yes, the plastic sleeve moves in and out.
    • John N.
      • April 9, 2012
      • 17
      Thank you, I tried to figure it out and it just seemed that it would from a logical point of view, but I just did not know. Again, thank you.
