Are 66 l79 fuel pump to carb fuel line and fittings chrome plated like the 65 cars? Also does anyone have pictures of the fuel fittings for a 1966 l79 car. If possible a picture of the fitting itself and a picture in the fuel pump. Thanks
1966 L79 fuel lines/fittings
Tags: None
- Top
- Top
Re: 1966 L79 fuel lines/fittings
The 1966 judging guide lists the fuel fittings to be chrome as well. Is the fitting directly into the fuel pump chrome as well? I cannot find any clear pictures of this.- Top
Here's a picture of my 66 L79 engine. The fuel pump is a later version, so not correct, but I believe the fuel line from the pump to the carb is correct. And yes, it is chrome all the way.
The valve cover are only temporary
. I took the finned aluminum ones off to protect them.
DonAttached FilesDon Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Mathew,
Here are three pics that you may have to zoom in on ,but should give you the whole picture on routing. I believe this to be the correct routing and the correct fuel pump. If not, hopefully others will correct me .
Jim- Top
