C1 Alignment - NCRS Discussion Boards
C1 Alignment
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 293
    C1 Alignment
    Frustrating morning at the alignment shop with the 62. Caster spec is 2 degrees +\- 1/2 degree. Best the tech could get was 1/2 degree on the passenger's side and negative .3 degrees on the driver's side. Any thoughts or ideas are appreciated.
  • Jim L.
    • September 30, 1979
    • 1817
    Re: C1 Alignment
    John, perhaps this is a dumb question, but are the aluminum shims present between the frame and crossmember?
    Jim
    • Terry D.
      • May 31, 1987
      • 2697
      Re: C1 Alignment
      Find a new shop that knows how to work on old front ends.
      • Frank D.
        • December 27, 2007
        • 2703
        Re: C1 Alignment
        Yes - find a shop with an older machine (and an older operator); even then if any of that center-link/king-pin front end is boogered up a compromise may be the best you can get...
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11360
          Re: C1 Alignment
          My experiences have taught me why this may be happening......
          When the upper outer and lower outer pins/pivot bolts/bushings( "trunnions" as a old timer taught me years ago ) are installed it the control arms, it is important to center them in the center of the opening in the control arms. If there is offset in one direction on one arm, and if the opposite arm's end is offset in the other direction, this can accumulate and yield a error in caster adjustment capability.
          Take a close look at each outer upper and lower bushing. If they are off center, this could potentially cause a problem of this nature.
          As can be seen in the ST-12 CSM below(fig 16), the center of the bushing with respect to the lower outer control arm opening can be offset if not installed with care.
          The same is true for the upper as seen in Fig 23....
          If there is obvious offset in the bushings with respect to the arm openings, it may be necessary to disassemble the suspension to an appropriate level and re-center the bushings to correct the errors.
          Rich
          • Dan P.
            • December 1, 1990
            • 683
            Re: C1 Alignment
            The aluminum shims are tapered which installed correctly increases positive Camber . Make sure they are in there and installed correctly.
              Re: C1 Alignment
              Dan -
              I think you meant "increases positive Caster", not camber.
              • Dan P.
                • December 1, 1990
                • 683
                Re: C1 Alignment
                My mistake. I meant caster.
                • Roger W.
                  • January 29, 2008
                  • 571
                  Re: C1 Alignment
                  Dan,
                  Where are these shims located? I don't see them mentioned in the alignment section of the service manual.
                  • Dan P.
                    • December 1, 1990
                    • 683
                    Re: C1 Alignment
                    Between the cross member and frame .The bolts that hold the cross member to the frame go though them.Here is the link to Corvette Central.http://www.parts123.com/corvettecent...50e&ukey=47316
                    • Roger W.
                      • January 29, 2008
                      • 571
                      Re: C1 Alignment
                      Thanks Dan.
                      The shims are shown in the service manual, but they are not labeled as to what they are. I learned something new today.
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        Re: C1 Alignment
                        All C1s had the shims installed starting in 1956. 53-55 are out of luck.
                        • David S.
                          • December 1, 1982
                          • 310
                          Re: C1 Alignment
                          Troy I disagree a bit with your statement. Shims were not added until late in the 1956 production year.
                          • Brad K.
                            • August 31, 1990
                            • 414
                            Re: C1 Alignment
                            Some of you may have a hard time believing this........but I saw it with my own eyes.....Years ago I bought a '60 with a very bad case of negative camber (the top of the tires were much closer together than the bottom). I took it to the only place in town with a "Bear Alignment" sign out front with an "old timer" in charge of the shop. He confirmed that the pivot pins and their eccentrics were indeed out of range. They simply could not be rotated further to get anywhere near the desired positive camber. "No problem" he remarked, as he actually chained down both sides of the front end of my car and placed a large hydraulic jack under the center of the crossmember. At which point he and his loyal assistant applied heat (from two acetylene torches) to the upper ends of both knuckle supports. After they began to glow cherry red hot, he then began to apply upward vertical force via the hydraulic jack. Using his "highly trained eye" (no digital electronics here) the knuckle supports began to BEND ever so slightly......to the point where the pivot pins were magically returned to the center of their range. He smiled and said, "Yep....must have been some kids driving the hell out of the car and jumping over some railroad tracks!"
                            He finished the alignment and I happily drove off with what I came for.....a slightly positive camber!
                            • Roger W.
                              • January 29, 2008
                              • 571
                              Re: C1 Alignment
                              Brad,
                              I believe the story. I was told that a torch had to be used to align the front end of my 59. I was not there when it was done, but they probably did a procedure similar to what was done to your 60.
