68 Air Conditioning compressor muffler - NCRS Discussion Boards
  • Dan L.
    • November 8, 2010
    • 27
    I'm missing all the engine compartment air conditioning components for my 68. This is an original AC car and I want to reestablish the air conditioning. Most of the parts I need are available with the exception of the compressor muffler which was only used for the 68 model year (used mufflers are extremely expensive). As I don't plan on having the car judged I am thinking of ordering a 67 muffler which fits on the A6 compressor. Has anyone else done this with success? Any advice would be appreciated.
    The engine is a 327.
    Dan Leslie
  • Harry S.
    • July 31, 2002
    • 5346
    Re: 68 Air Conditioning compressor muffler
    Dan Leslie
    I would think a 60's A6 muffler would be fine.
    Did you see ------> http://www.ebay.com/itm/MINT-ORIGINA...301f4d&vxp=mtr
    • Edward B.
      • March 29, 2013
      • 691
      Dan, if you're referring to the 3923139 muffler, that was used on the Corvette from 63-68 and on a lot of other passenger cars and trucks. i.e., 1964-1968 Chevelle (6 cylinder), 64-72 10, 20 and 30 series trucks (6 cylinder), etc...
      Shouldn't be that difficult to find one with a reasonable price.
      Ed
      • Paul O.
        • August 31, 1990
        • 1716
        Dan
        Doc Rebuild sells a new one here is a link.
        1963-1968 Corvette Air Conditioning Fitting with Muffler original GM 3923139 NOS made in the USA. Not an import. 1963 1964 1965 1966 1967 1968
        • Wayne M.
          • March 1, 1980
          • 6414
          Ed
          Ed, Dan --- Here's a 3923139 that I bought from a local Calgary Alberta Chev dealer in the early '80s. As you mention, my P&A30B catalog shows this as '68 and services all Corvette back to '63. Anyway, I knew it wasn't correct for my '65. I put it on just to have something to connect the hoses to; I never got my air working (nor do I need to in the far north ), so it's never seen Freon. The hex caps are brass with cad plating, which is partially worn off.
          Appreciate if a '68 expert can tell me if this is really the correct "production" configuration.
          • Dan L.
            • November 8, 2010
            • 27
            Good info. Thanks to all for your responses.
            Dan
