Re: This is what the A-6 compressor drain plug is for!
Rich,
May be rust as the compressor is the only one in the system that will rust. Mineral oil doesn't prevent rust... Try to turn the hub clutch anain. The guts ate strong. If it turns slowly it would seem like a hydraulic lock, but that doesn't seem possible because the oil would drain down into the oil pan. The system would have had way to much oil and would not have cooled very well.
I am thinking rust. Try turning the 9/16 nut in the center of the hub and see if it will turn. If you think you are putting to much on the nut then take a belt and wrap it around the rubber on the hub clutch and try it that way. the belt off your pants will do it also.
Feel free to call me. (760)831-2095
Dom
Rich,
Dom
Never did determine why the ACDELCO ones would seize......although both were returned for credit as mentioned above.
