Parts list help - NCRS Discussion Boards
Parts list help
  • Donald O.
    • May 31, 1990
    • 1593
    Parts list help
    I have a friend that is installing a 454 crate engine into his 1967.
    What aluminum bellhousing, clutch and flywheel should he use? He will be using a Muncie 4 spd. He doesn't know if its a CR or a WR unit.
    Also what clutch fork, pivot stud, and Z-bar should he use, or will the SBC Z-bar work and parts work?
    His car his choices........he will be pulling his original 300hp sbc out (and storing it) to do this wasp. So would he also need a BB hood for carb clearance?
    Thanks in advance
    DonO
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: Parts list help
    621 bell housing with an 11 inch clutch assembly
    Either Z bar will work but the clutch rod from the z bar to the fork might need adjusting All studs equal
    Hood definitely needed
      • 43288
      Re: Parts list help
      Thanks in advance
      DonO
      Don------
      He can use either the existing '3858403' bellhousing or he can change to the 3899621. If he uses the '403', then he needs to use an externally balanced 12-3/4" flywheel. If he uses the '621', then he needs to use a 14" flywheel. Either way, he needs a flywheel which is externally balanced and compatible with a 1 piece seal crankshaft (since almost all current crate 454's use the 1 piece seal). The 14" flywheel will be GM #14096987. GM no longer offers a 12-3/4" flywheel for this application but I think they are available in the aftermarket.
      GM does not offer a clutch for this application. No problem, though. Use a LUK. Assuming the Muncie is a 10 spline input (which all original 1967 Muncies used) and with the 14" flywheel use a LUK Repset 04-049. If it happens to be a 26 spline input (i.e. not an original 67 transmission), then use LUK 04-020.
      If the transmission is the original one from his car it will be a wide ratio. No close ratio was available with the 300 hp engine.
      For a 1967, the clutch fork, pivot stud and z-bar will be the same as was originally supplied with his car.
      For a 1967 he MIGHT, and I stress MIGHT, be able to use the stock small block hood with a big block if he uses the 1970-71 LS-6 intake manifold, GM casting #3963569. However, for this to work he must have a big block with rectangular port heads. If he has a big block with oval port heads, the Edelbrock Torker II MIGHT, and I stress MIGHT, work with a small block hood. If you can advise as to the part number of the crate big block he is using, I should be able to advise as to which heads it has. By the way, I don't like the Torker II for street applications but, if he has oval port heads, it's the only one I know of that MIGHT work with a small block hood.
