Timkin Bearing Part Numbers - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 977
    Does anyone have access to the correct part numbers for Timkin front and rear wheel bearings ?? All four of them if possible
    • 43289
    Re: Timkin Bearing Part Numbers
    Jimmy------
    What year car? It matters for the fronts.
    Anyway, here it is for both
    FRONT
    63-68 front outer------SET 2
    63-68 front inner------SET 6
    69-82 front outer------SET 3
    69-82 front inner-------SET 5
    REAR
    63-82 rear outer--------SET 5
    63-82 rear inner---------BEARING M86649; RACE M86610
    • Jimmy G.
      • November 1, 1979
      • 977
      It is a 1965
        • 43289
        It is a 1965
        Jimmy------
        You can order the Timken bearings by the set numbers I provided above. The SETS include BOTH the bearing and outer race ("cup"). Otherwise, you have to order the bearings and outer races separately and that's not the best way to go. Unfortunately, there is no set available for the rear inner bearings because they do not have wide application, so you have to order the bearing and race separately.
