62 speedo bouncy needle - NCRS Discussion Boards
  • Wally A.
    • May 31, 1979
    • 170
    sent my 62 speedo head out for repair, worked great except for a bouncy needle at cruising speeds
    well, was i sticker shocked. not to mention who i sent it to. was told only way to
    repair is for a complete rebuild.... over 525.00 decided to pick up , any suggestions for a plan B
    or is it really neccessary for what i was told. like having a flat tire and buying 4 new tires to fix
    a problem. thanks for your input....
  • Kenneth B.
    • August 31, 1984
    • 2090
    Re: 62 speedo bouncy needle
    It's out & at the shop. Having the whole speedo redone makes sense to me It's like doing a partial engine rebuild. It makes no sense.
    • Mike T.
      • January 1, 1992
      • 568
      Wally - Any 'noise' from your speedo housing while it's bouncing?
      Mike T. - Prescott AZ.
      • Vinnie P.
        Editor NCRS Restorer Magazine
        • May 31, 1990
        • 1567
        Wally...very often the fix is to lubricate the cable...I would start there first...
        • Wally A.
          • May 31, 1979
          • 170
          for starters, i put a drill motor on back of speedo head and still see needle bounce.
          is this correct to say the problem is in the head and not the cable? or hooking a drill motor
          is not the right thing to do. the speedo works fine with no noise, just a 10 mph jump back and forth
          • Mike T.
            • January 1, 1992
            • 568
            Wally - Which way did you have the drill turning?
            • Wally A.
              • May 31, 1979
              • 170
              backwards, the only way it will read MPH
              • Mike T.
                • January 1, 1992
                • 568
                Just checking - I've never tried it forwards and was wondering if you did check it that way would the needle still bounce but only hang around the starting peg.
                • Terry D.
                  • May 31, 1987
                  • 2692
                  You might check with other repair shops. Some are listed in the driveline. Ask for references. There is a wide range of prices to fix any old gauge. Some shops believe that because you own a collectable you have money to throw away.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    I'd call and talk to Bill Harrison down here in Florida: http://www.harrisonspeedometer.com/contactme.html
                    He is used by a lot of my Corvette pals. $525 seems high to me for repairing a bouncing needled - but I haven't had gauge work done in 7 years so who knows ??
                    • Harry S.
                      • July 31, 2002
                      • 5310
                      I'm with Vinnie, start with the cable.....Remove it from the car, clean the inside of the outer cable, clean the inner cable, lube the inner and put it back together.
                      • Brian T.
                        • September 30, 1990
                        • 190
                        You may also look for any signs that grease has worked its way up the cable and into the mechanism. That is a no no. Excessive bounce can also break the pointer, and may indicate the speed cup is going to fail.
                        • Joe R.
                          • July 31, 1976
                          • 4551
                          It should cost no more than $185.00 to completely rebuild the frame with new bearings, new #1, new #2 and new #3. That should fix any speedometer. Now that is not a cosmetic rebuild but it should work for another 100,000 miles or more. Of course that won't include shipping!
                          JR
                          • Wally A.
                            • May 31, 1979
                            • 170
                            that kind of price to do a repair as you noted, sounds great, can you give me a name.
                            thanks for your input wally
                            • Willard M.
                              • August 31, 1979
                              • 422
                              Various rebuilders advertise in the Driveline. I had my 54 speedo rebuilt by D and M Restorations, 800-722-0854. They fixed my bouncing needle and quick turn around. I don't recall the cost but is wasn't $525.
