Garage exhaust hose - NCRS Discussion Boards
Garage exhaust hose
  • Michael B.
    • April 1, 1999
    • 178
    Garage exhaust hose
    Anyone know of a source of garage exhaust hose in the Markham (Greater Toronto Area). None of the usual automotive supply shops seem to carry this stuff. Looking for 2 3" hoses to a Y to a door port.
    Michael B
  • Scott S.
    • March 1, 1979
    • 747
    Re: Garage exhaust hose
    Acklands Grainger carries the Exhaust Hose but it is pricey. Have you tried flexible down spout hose from CTC or Home Depot?
    Scott
    • Michael B.
      • April 1, 1999
      • 178
      Scott
      Hi Scott, considered cloths dryer flex vent as well but I though the temperatures would be too high from the exhaust tip and the plastic of the tube might melt from the exhaust gas. I'm not worried about crush-proof, just safely venting. Anyone else tried the cheap options with success ???
      Cheers.
      Michael B.
      • Steven B.
        • June 30, 1982
        • 4016
        Michael, years ago when I lived where there was winter I used metal flex exhaust from JC Whitney. I made a simple tailpipe to flex adapter and it held up well. The garage stayed "a bit" warmer. Steve
        • Doug M.
          • January 1, 1991
          • 68
          aluminum flex liner for a gas chimney.
          Doug
          • Michael B.
            • April 1, 1999
            • 178
            Doug
            Fantastic idea.
            Could even use an inline vent fan to help draw it out.
            Thanks.
            Michael B.
            • Enzo C.
              • January 12, 2012
              • 536
              As a HVAC contractor we buy 25 foot chimney liner kits for our fireplace insert installs... that should work fine as they are fairly ridged.. good call Doug,
              Enzo Colosimo
              Ncrs Ontario Chapter Chairman 🇨🇦
              ENZ-Z06/67
                I used 4" corrugated aluminum dryer vent pipe, clamped to my 4" open sidepipes, to get the fumes and noise out under the garage door in the dead of winter when I did the first-fire on the 383 I built for my tube-frame Grand Sport replica back in 1995; worked great, and was pretty cheap.
                • Steven B.
                  • April 11, 2012
                  • 233
                  I found some on Amazon. Tubing, Y, and port.
                  Steve
