94 LT-1 cooloant hoses - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1600
    does anyone know if the heater hoses on a 94 lT-1 are still available from GM. and if so part numbers. I need the ones I am pointing too(all four).
    this will never be a judged car. this is my daily driver
  • Guest
    Re: 94 LT-1 cooloant hoses
    Keith - check out gmparts.direct.com at the following link - have pix and part numbers
    http://www.gmpartsdirect.com/catalog/frameset.cfm
    Part Number: 10258276
    upper hose 1990-96, w/o ZR1, rear
      • 43273
      Keith------
      The only heater hose still available from GM for your application is GM #10157913. I don't think it's any of the ones you point to.
      Some of them may be available in the aftermarket from Gates, Dayco, or Goodyear.
        • 43273
        Rick------
        Yes, those hoses are available. However, those are radiator hoses and not heater hoses.
        • Keith B.
          • 1600
          Thanks that gives me something to work with.
