Joe L what's the application for radiator code ML? - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2162
    Joe, Can you tell me what is the application for C3 radiator code ML?
    • 43246
    Re: Joe L what's the application for radiator code ML?
    Russ------
    "ML" is the code for radiator GM #3035856. This radiator was used on many 1976-79 Corvettes with heavy duty cooling.
    • Russ S.
      • April 30, 1982
      • 2162
      Thanks Joe. Can you get me one more please. How about code MF?
        • 43246
        Russ-----
        The only radiator I can find with an "MF" code is one used during the 1980-81 period and of GM #3043390. However, this was not a Corvette radiator. It's very possible that the code "MF" was used earlier for a Corvette radiator but I have no information on that.
        The PRODUCTION radiator for your application was supposed to be GM #3028081. It's possible this radiator used code "MF". However, I cannot confirm that. GM #3028081 was never available in SERVICE.
        • Russ S.
          • April 30, 1982
          • 2162
          Unfortunately I can't see the part number on my MF tag as it is behind the radiator shroud. Thanks
          • Russ S.
            • April 30, 1982
            • 2162
            Joe, the part number on the ML tag is 3027968 Also the date on this radiator tank is 2 L--72 nov
            Russ------
              • 43246
              Russ------
              Apparently, the "ML" code was used prior to the 1976 model year for a completely different radiator. This is not unusual. The radiator broadcast codes are specific to a particular model year or range of model years. They are re-used and assigned to different radiators.
              The GM #3027968 radiator is a PRODUCTION-only radiator; it was never available in SERVICE. That's why I had no record of the "ML" broadcast code being assigned to it.
              • Russ S.
                • April 30, 1982
                • 2162
                Thanks Joe. That sheds some light on it.
