67' Engine mount: Non locking vs locking - NCRS Discussion Boards
  • Steven B.
    • April 11, 2012
    • 233
    Re: 67' Engine mount: Non locking vs locking
    I think that small block trucks were a main concern because of all the room they had for the engine to move around. I don't know about the passenger cars.
    Steve
    • Bill L.
      • April 1, 1985
      • 349
      Here are the rework instructions for the V-shield "boomerangs" when the original engine mounts are replaced by the later (and slightly larger) locking mounts.
      [ATTACH=CONFIG]59684[/ATTACH]
      Thank you John -- this is VERY helpful ----!!!
      Any chance that we can get a version that is a bit clearer? Maybe the actual .JPG file? Or location of same? This one is a bit hard to read the measurements. I tried zooming it in a bit but it gets pretty blurry.
      Thanks!!!
      Bill
        • 43219
        #18
        Thanks!!!
        Bill
        Bill-------
        This instruction sheet was included with GM motor mounts for years.
        However, if you're going to use locking type motor mounts, which I HIGHLY recommend, I also recommend that rather than modifying the original "boomerang" shields you just buy a set of reproduction 1970-72 shields which are designed for the locking style mounts. Many years ago when I first installed the locking style mounts on my 1969, I did modify the original shields as instructed. I wish I hadn't, though.
        • Bill L.
          • April 1, 1985
          • 349
          #19
          Thanks Joe --- I will look into it --- I always like to keep things original if I can but safety trumps originality for me (In most cases!!)
            Thanks!!!
            Bill
            Bill -
            The board software automatically reduces higher-resolution images; shoot me an e-mail (Snake488@aol.com) and I'll send you the higher-resolution original image.
            • Bill L.
              • April 1, 1985
              • 349
              #21
              Thanks John!
              • Bill L.
                • April 1, 1985
                • 349
                #22
                Thanks John!
                • Paul Y.
                  • September 30, 1982
                  • 570
                  #23
                  I owned a 1965 Bel Air 2 door back in the day that used to break them pretty regular and would give a pretty exciting ride until the cable repair was finally installed.
                  Steve
                  It's a good life!
                  • Robert G.
                    • May 31, 1990
                    • 429
                    #24
                    This is what the cable fix looked like.
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      #25
                      Robert,
                      Nice picture. Somehow I thought they bolted one end to 1 of the 3 screws that held the mount to the block, and the other to 1 large bolt that went thru the mount that connected it to the frame mount.
                      Dom
                      • Robert G.
                        • May 31, 1990
                        • 429
                        #26
                        I'm guessing the fix was different for different models. I saw one online for 302/Z28 that looked different. My photo is for the Bel Air 327.
                          • 43219
                          #27
                          Robert------
                          There were. There were several different kits for different chassis/engine applications.
                            Parts below are for the Camaro and Chevy II/Nova - Corvette and Chevelle weren't affected by the recall, as their throttles didn't go to WOT when the engine mount separated and the engine torqued up on the driver's side.
                              • 43219
                              #29
                              [ATTACH=CONFIG]60102[/ATTACH][ATTACH=CONFIG]60103[/ATTACH]
                              John-------
                              I've got a couple of the GM kits in my collection. Each is different from the other and different from the one you pictured. I don't recall what chassis/engine applications they are for, though.
