How Many Holes in a 1967 Frame are there? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11327
    This is a Poll linked from This Thread....
    https://www.forums.ncrs.org/showthre...me-Restoration
    I taped every hole on the frame. I'll be using a wand to apply the internal frame paint, un-taping appropriate holes where needed to get each internal section.
    How many holes did I tape off ?
    14
    75
    0%
    1
    100
    0%
    2
    125
    0%
    7
    150
    0%
    2
    175
    0%
    1
    200
    0%
    1
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11327
    Re: How Many Holes in a 1967 Frame are there?
    It was more than 50, and less than 225.
    • Loren L.
      • April 30, 1976
      • 4104
      It depends - did the frame live in Cleveland or Phoenix?
      • Joe R.
        • July 31, 1976
        • 4551
        Rich,
        Is this survey going to be included in the Judging Manual for 1967????
        I think not!!!!!!
        JR
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11327
          Loren, I'm not sure where it lived, but I did find 3 holes more than AO Smith punched. Only they were jagged instead of round.
          Joe, I sure hope the JG does NOT include my total, as we'll need more than one frame to get a average.
          Rich
          • Gary B.
            • February 1, 1997
            • 7046
            Rich,
            I'm dying to hear the answer!
            Gary
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11327
              If your eyes are good you can see the green tape in my pictures, but not the bottom.
              Hint.....more than 100, and not counting the frame horns up front which aren't "internal".
              I'll give in by Wednesday.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11327
                I finished the black internal coating today. Sometime tomorrow I'll remove all tape and get a recount. I'll post it sometime tomorrow.
                Still time to guess.
                Rich
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11327
                  Answer..................196
                  pics back at the main thread.
                  https://www.forums.ncrs.org/showthre...269#post739269
                  Rich
                  • Tom K.
                    • February 26, 2008
                    • 167
                    Thanks Rich. I guess I need to buy extra masking tape before I start on mine.
                    Tom
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      .... I'll be using a wand to apply the internal frame paint, un-taping appropriate holes where needed to get each internal section. ....
                      I'd just like to know what type of wand you used to paint the inside of the frame. I tried a pump up garden sprayer and made a disaster of the project.
                      tc
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11327
                        Tom
                        Tom, I painted the top and sides yesterday. In the process, I found one more under the DS #4 body mount !!!! Total adjusted to 197.
                        tc
                        Tracy, I used this kit from Eastwood. It worked very well. Two wands are included. The tip I used has 6 nozzles. One on the end and 5 on the perimeter. I had to thin the materials a bit to get a good spray pattern.
                        • Tracy C.
                          • July 31, 2003
                          • 2739
                          Thank you Rich..I assumed you used something like POR15 for the paint?
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11327
                            Hi Tracy, buried in the main thread I show what I used. It's the Eastwood Internal Frame Coating.
                            I used the bulk quart with the gun. I bought 2 but only needed one, slightly thinned to help it through the wand nozzle easier.
                            Destroys rust hiding inside the chassis, rocker panels and pillars so it won't rust through
                            Here are some direct links to the posts inside the main thread.
                            This post shows when I used it inside the endcap cavities before I closed it up. I just brushed it on inside each one....
                            https://www.forums.ncrs.org/showthre...596#post738596
                            This post was the day I used the coating with that gun/wand setup....
                            https://www.forums.ncrs.org/showthre...930#post738930
                            Rich
                            • Tracy C.
                              • July 31, 2003
                              • 2739
                              Thank you Rich..very helpful info. Not sure how I missed this thread the first time around.
                              tc
