Battery drain 1982 Collector car - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    I have a battery drain that will fully discharge the battery in about a week on 1982 Collector Car, My solution was to disconnect the battery when not in use. A friend just acquired a 82 Collector car and has the exact same problem. Can't find any obvious solution. What's going on??
    Ted
  • Keith B.
    • September 15, 2014
    • 1604
    Re: Battery drain 1982 Collector car
    Try to narrow it down by pulling one fuse at a time and check the battery volts with a meter
    • Ted K.
      • August 31, 1994
      • 337
      I was trying to avoid doing that because of the difficult location of the fuse panel. I was thinking because the same problems showed up on two identical 82 vettes there might be a typical/similar problem with the Collector Car.
      • Robert R.
        • May 31, 1975
        • 358
        Ted
        On most cars that still have electronic clocks, the solenoid will slowly discharge the battery when the car is not used daily. Suggest a battery tender for the time off not using your car.
        Bob
        • Jim T.
          • March 1, 1993
          • 5351
          Hope you find your battery drain Ted. I disconnect my c3's batteries negative cable when the cars are not going to be used. I disconnect the negative cable from the frame, real easy access and real quick using a short ratchet and socket. Sure is easier than going behind the drivers seat and disconnecting the negative cable in the battery box.
          • Michael W.
            • April 1, 1997
            • 4290
            I don't know of anything unique to the CE that might be causing this problem. Standard troubleshooting should be able to pinpoint the cause.
            • William C.
              • May 31, 1975
              • 6037
              Another question is "how good is the Battery"
              Bill Clupper #618
              • Ted K.
                • August 31, 1994
                • 337
                Battery is new and starts out fully charged.
                • Ted K.
                  • August 31, 1994
                  • 337
                  Thanks, I'll check out where that ground attaches to the frame.
                  Do you disconnect them because they drain the battery if left connected?
                    • 6957
                    Ted, nose around and look to see if anything is lit such as a glove box light, and not sure if 82 had it but the use to a lamp under the spare tire area, under hood light, these are common things to give a draw on the battery.
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Ted I disconnect the negative cable just to maintain the current battery charge. My C3's can sit for weeks. I believe/think the size of the bolt attaching the negative cable to the frame is 5/8's.
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        The car should be able to sits for months without the battery going dead.
