I am trying to replace my rear door ajar/alarm switches on my 73. Both of the switches are non-functional. The one on the right side is missing, I assume it is down in the frame. The one on the left is rusted, held on with two small flat head screws, and the pin is smashed in. I removed both of the wheel well inner access panels on both sides. The right side just had two wires (no red) present that were broken off on the ends. I'm sure the switch is down in the frame. On the left side I found the switch still present. After removing the rusted screws I did pull the switch back through the TINY hole. It was still attached to the backing plate. It had two wires a light blue and a white/tan colored wire. There was also a third Red wire attached to the mounting plate. While pulling the wires off, the red wire broke free from the plate. The other two wires were plugged in with slide on clips. After removing the wires the plate fell down in the frame. When searching the vendors catalogs for the correct 73 switch I didn't see one that had the same type of end that lets the wires slide on. The switch they list for 73 doesn't look like mine. Also, none of the mount plates had anything where the Red wire would attach. BTW, the # 3 body mounts were in pretty good shape considering. So I sprayed them with PB Blaster/ Rust Inhibitor after cleaning out the area. Also, in the parts searching process I noticed two stick on pads that go on the doors. They only suggest them to be used up to 72. But my doors have a square area that looks like a pad was there at one time. My jams are still in original paint. Do the 73's use the pad? I know many have gone through this. I would appreciate any help with which is the correct switch to use. Finally: HOW IN THE WORLD DO YOU GET THE NEW MOUNTING PLATE BACK THROUGH THAT LITTLE HOLE?
