1956 Exhaust Manifold Restoration - NCRS Discussion Boards
  • James R.
    Infrequent User
    • December 1, 1975
    • 1
    I'm in the process of restoring my 1956 Corvette convertible and am wondering if a heat riser or spacer is required on the two 4 barrel. Engine is 225 horse, second design.
    TIA
    Jim
  • John C.
    • July 11, 2011
    • 122
    Re: 1956 Exhaust Manifold Restoration
    Hi Jim,
    I believe the '56 2nd design requires a 3 bolt flat gasket/thin heat riser as opposed to a '57 that uses a doughnut type gasket.
    John
      • May 31, 1974
      • 8400
      heat risers were originally installed on the 265 56's regardless of early or late exhaust manifold type. mike
      • Edward M.
        • November 1, 1985
        • 1922
        Mike hits the nail on the head again. The three bolt 56 heat riser valve is unique to 56. The 6th edition of the 56-57 Judging manual has a nice picture of an original part.
