L71 oil pressure , fitting location - NCRS Discussion Boards
  • Dave C.
    • March 20, 2014
    • 253
    Just trying to figure out where the oil pressure line taps into the block, I've searched the archives and looked at every picture I could find there are three holes above the filter, which one is it?
  • Michael B.
    • June 18, 2007
    • 400
    Re: L71 oil pressure , fitting location
    The line configuration changed between 1968 and 1969 but the upper right is the clutch linkage pivot, the center fitting is pressure out for the gauge and/or remote filter and the one on the left is oil return for a remote filter.
    • Dave C.
      • March 20, 2014
      • 253
      Thanks Michael , I forgot to mention that the car is a 67, but I am. Sure they would be the same, I guess I need another adapter if it is the centre one
      • Robert D.
        • March 31, 2003
        • 305
        Dave mine comes out where the left plug is its a 67 if its not correct maybe someone will chime in but i believe it to be correct
        • Dave C.
          • March 20, 2014
          • 253
          Thanks Robert, if that one works, I might as well use it since the fittings I ordered from Paragon fit that hole, not sure why they are all. Plugged off on this block but glad to see a picture of a real car, thank you.
          • Michael B.
            • June 18, 2007
            • 400
            This is for the 1968.
