73 Right Side Ignition Shield Bracket - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1696
    Trying to decide if I have the correct right side orange top ignition shield support bracket on my73 L48. Mine is currently attached to the last rear top bolt on the intake manifold. However, I see some photos of this RH side bracket attached to the second from the last bolt. This bracket appears to slant back and up for the wing nut to attach. My bracket is more vertical. The reason for the question is that I want to attach the engine lifting eye on that side in the correct spot. When I got the car, the shielding was missing but all came with the car and the lifting eye was attached to the last top bolt on that side of the manifold. The judging manual says it is to be attached to the passenger's side bell housing to block attaching bolt.?? Is that back at the firewall area lower on the block? The manual doesn't say which top manifold bolt the bracket should be attached to. The manual actually says it is held on with nuts.???? If my bracket is incorrect does anyone know the correct part number? All those I've seen look like the one I have on my car. Thanks
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 73 Right Side Ignition Shield Bracket
    The ignition bracket goes on the second bolt. The bracket should slant back and up. Check your driver side. You may have them reversed. Driver side goes on the rear bolt and is straight up.
      • 3416
      Hi Jimmy,
      Here's a picture of the lifting bracket on my 71 sb. I'd think the one for your 73 would be in the same position.
      It's the top bolt on the right side of the bell-housing.
      Please disregard the amount of chevy orange on this engine! You're seeing the upper rear corner
      of the valve cover on the right side of the picture.
      • Jimmy P.
        • June 24, 2014
        • 1696
        Thanks Alan,
        My 73 rear engine lift eye isn't the same as your 71. I included a photo of what it looks like. It will bolt to my last top right intake manifold bolt after I replace my RH top shield bracket with the correct one. However ,still not clear as to where the judging manual says it should go???
        Jimmy
        1973 Convertible
        L48,M20,N40
          • 6945
          Jim, the brackets for a auto transmission and a 4 speed are different. I think Alan's car is a 4 speed. and believe they changed just about each year my 72 only has one bracket on the left front for some reason the small block Auto trans. use only the one. The 4 speeds are like Alan's.
            • 3416
            Hi Edward,
            Good to talk to you!
            Thanks for the additional info!
              • 3416
              Hi Jimmy,
              From your signature I thought you were asking about a 4 speed car. Are You?
              I've always thought the bracket I showed was used from 68 onward as the rear bracket for sb engines.
              But perhaps I'm wrong.
              • Jimmy P.
                • June 24, 2014
                • 1696
                Yes Alan, I have a 4 speed car. This may or may not be something that needs corrected in the 73-74 judging manual, or it may just be me not reading it correctly. The manual says the front lifting eye I s attached to the drivers side front of the intake manifold's front two bolts.It is engine orange and occasionally has the "omega symbol" stamped on it . Another bracket attaches to the passenger side bell housing to block bolt on the L48/L82's, and to the rear of the passenger side head on the LS4. The bracket (the one in my photo) attaches with one bolt and is also engine orange. My front bracket was attached correctly as noted above, but it has no "omega symbol". My rear bracket as pictured was bolted to the last bolt on intake manifold on passenger side. (It has the "omega symbol "stamped on it). I tried to place my rear bracket back by the bell housing to see if it would bolt somewhere but couldn't find a place it would fit. This really gets confusing!
                Jimmy
                1973 Convertible
                L48,M20,N40
                  • 3416
                  Hi Jimmy,
                  If you tried to place the bracket in your pictures on the top right bell housing bolt I can understand it not fitting. It seems to be for another application.
                  I believe the rear bracket needs to be configured like the one in my picture for use on 4-speed cars.
                  They are readily available from various venders, but often only in pairs. Perhaps you can find a used one.
                  • Jimmy P.
                    • June 24, 2014
                    • 1696
                    Thank you, I'll check them out, and make sure I get the correct one for the 73 SB/4speed. I guess I can add this to the list of items not correct on my car.
                    Jimmy
                    1973 Convertible
                    L48,M20,N40
                    • Larry M.
                      • December 1, 1986
                      • 541
                      Jimmy,
                      For what ir's worth, both ZIP and Dr. Rebuild list only one set of brackets for all 1971 through 1982 small blocks. They make no distinction between auto/4-speed, or L48/LT-1/L82.
                      Larry
                      • Jimmy P.
                        • June 24, 2014
                        • 1696
                        Thank you for all you input.
                        Jimmy
                        1973 Convertible
                        L48,M20,N40
