I'm at my wits end.
I can't get my brakes to bleed.
Ok before everyone jumps on me; let me explain my nightmare.
I have done the following.....
all new lines. Master cylinder. Booster.
stainless sleeves with o-ring seals.
bench bled the MC.
motive power bled all four corners.
still soft pedal.
maybe bad MC. Plugged both sides. Firm as can be.
Attached power bleeder and cracked every fitting starting close to the MC and working my way to the calipers.
STILL SOFT PEDAL
opened bleeds rapped on calipers.
checked proportioning valve. Bled all connections again.
still soft pedal.
Couple things I noticed.
the pedal is fairly stiff and feels normal until it moves a half inch or so. Then it goes to the floor.
with the engine running repeated pumping effects idle.
it's a new booster. I checked for vacuum leaks. Can't find any. No fluid in booster.
I don't see any leak at the calipers.
Argh!
bench bled the MC.
still soft pedal.
STILL SOFT PEDAL
still soft pedal.
Argh!
