Anyone know what these cylinder heads are? - NCRS Discussion Boards
  • Eric J.
    • March 1, 1980
    • 771
    I picked up a set of cylinder heads thinking they were 186 LT1 heads, but they are not. Does anyone know what they are?
    There is no part number cast in the head. Only 3.23 and 180 cast
    Thanks Eric
    • 43219
    Re: Anyone know what these cylinder heads are?
    [ATTACH=CONFIG]58836[/ATTACH]
    [ATTACH=CONFIG]58837[/ATTACH]
    [ATTACH=CONFIG]58838[/ATTACH]
    [ATTACH=CONFIG]58839[/ATTACH]
    Thanks Eric
    Eric------
    I have never seen a set of GM heads that didn't have a casting number on them somewhere. In any event, these are DEFINITELY NOT GM '186' heads. Based on the end configuration, I'd say they are much later heads
    Obviously, Competition Cams guideplates, if not other parts, have been installed on these heads. These guideplates are not even configured like the GM guideplates.
    • Eric J.
      • March 1, 1980
      • 771
      Joe, thank you. I know now they are not 186s I just find it odd there are no part numbers anywhere. I assume they are some aftermarket manufacture. The mystery continues....
        • 43219
        Eric-----
        They could be aftermarket. However, the end configuration is more-or-less like later GM heads and the date code configuration is very "GM-ish". But, I've never seen any GM heads without a casting number. Even aftermarket heads usually have some sort of manufacturer's ID.
        • Terry D.
          • May 31, 1987
          • 2691
          It looks like the 3;23 is a plate, did you try to take it off to if anything is under it?
          • Mike F.
            • April 25, 2011
            • 668
            • Eric J.
              • March 1, 1980
              • 771
              Terry that's cast in the head. Both heads used the same casting as the screw heads are clocked the same.
              • Eric J.
                • March 1, 1980
                • 771
                Possibly C/n 376450; 350 1987-’94 76 cc 1.94" x 1.5" valves?
                [ATTACH=CONFIG]58872[/ATTACH]
                Mike the rocker stud "bosses" are different on my heads.
                • Eric J.
                  • March 1, 1980
                  • 771
                  There are a couple of differences.
                  • Eric J.
                    • March 1, 1980
                    • 771
                    Here are a couple more pictures.
                    They have the accessory tapped holes so they are after GM introduced the "Long Nose" water pump 1970? and there are temp sender holes in both.
                      • April 1, 2000
                      • 477
                      They remind me of very plentiful (and not necessarily desirable) late 70's/80's era "882" heads. They were produced for many years and had some differences thru the production run IIRC. Full cast number I think is 333882. I've never seen those without casting numbers. Interesting.
                      • Mike F.
                        • April 25, 2011
                        • 668
                        I know grasping at straws, but how about Mercruiser/Marine heads? http://bpi.ebasicpower.com/c/MER6N/C...for+Mercruiser
                        Similar casting marks at least.
                        • Philip A.
                          • February 26, 2008
                          • 329
                          They certainly do not look like typical GM manufactured heads based on the underside of the runners, markings and lack of markings (GM). It is possible they are aftermarket. If they were for sale I think they would be advertised as rare GM experimental corvette heads with no identification markings
                          • Eric J.
                            • March 1, 1980
                            • 771
                            I bet I could hook someone on eBay with that in the description lol.
                            • Eric J.
                              • March 1, 1980
                              • 771
                              I put a set of calipers on the valve openings this evening 2.02/1.60
