Re: "Heat Soak"
All the fuel is drawn by vacuum (technically it's all pushed by atmospheric toward the point with lower pressure, which we call vacuum,) except accel pump, which is pressurized. If that were not the case and fuel did not have to go up to a height above the level of the fuel in the bowl then back down or straight out it would run continuously. Gravity will do it's job and liquid will seek it's level. It's physics.
What you may be confusing this with is when you have a cross leak at the metering block gaskets. Fuel will leak across instead of traveling up and over.
Steve
Steve
