I believe the same under dash park brake handle bracket was used for 64 through 66. One difference is that in 66 the optional hazard flasher (V74) was mounted in a hole in the bracket. The AIM indicates the location and size of the hole, so that would lead me to believe the hole was drilled on the assembly line at some point, or did all 66s have the hole in the bracket to accept the V74 option?
My car has the hole, so does that mean it had the Hazard Flasher, or someone replaced the park brake bracket?
According to the black book, only 20% of the 66s had the V74 option. Given the low options of my car, it's hard to believe it came with V74 originally!!
Don
Don
