65 oil filter canister - NCRS Discussion Boards
  • Steve C.
    Infrequent User
    • June 26, 2012
    • 28
    Does anyone know the wall thickness for an original 1965 oil filter canister? I suspect the canister I have is a reproduction. It leaks oil down the sides when torqued to 25ft lbs. Wall thickness on this one is 0.102 in.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 oil filter canister
    Just measured (dial caliper) an original I have, and get from 0.080 to 0.090".
    • Steve C.
      Infrequent User
      • June 26, 2012
      • 28
      Wayne, thanks for the reply. I measured mine again several times with an electronic digital caliper and got between 0.102 and 0.107. Since my measurements are slightly greater than yours and your canister is original then I guess mine is too.
      • Don H.
        Moderator
        • June 16, 2009
        • 2283
        Steve
        check for double gaskets stuck up in the groove. Carefully pull one, then I bet you find another buried in there above it.
        Pull that one, and reinstall a fresh one.
        • Russ S.
          • April 30, 1982
          • 2163
          Repos aren't always thinner material. They could also be made from thicker material.
          • Leif A.
            • August 31, 1997
            • 3658
            Originally posted by Don Hooper (50543)
            Steve
            Agree. I think we have a winner.
            Leif
            • Stuart F.
              • August 31, 1996
              • 4676
              My understanding, after discussing this with one of the major vendors who reproduce the canisters, is that no one has a dye capable of drawing the heavy gauge steel used in the original GM units. They said that the GM dyes are no longer in existence. Therefore, it makes sense that if anyone has an original, it is better to have it restored than to buy a repro. Wish I would have known this sooner. I still alternate between my repro and original on every other oil change, but I'd rather use the original as it seems to seal better and I like the sense of security that the more substantial canister gives me against road debris.
              Stu Fox
              • Bill W.
                • March 1, 1980
                • 2000
                Steve my orig. 65 is 102 with a electronic digital caliper .
                • Steve C.
                  Infrequent User
                  • June 26, 2012
                  • 28
                  Problem with leaking oil canister solved. Paragon had replaced the bolt in my original canister and it was too long. I cut off 1/8 inch, torqued it to 25 ft lbs and no leaks. Thanks for the suggestions.
                  • Leif A.
                    • August 31, 1997
                    • 3658
                    Congratulations on finding and solving the problem...thanks for reporting your results. Love the aftermarket stuff.
                    Leif
                    • Guest
                      I was a supervisor in the AC department that made the canisters in 1960. My recollection is that they were made on a 600 ton transfer press utilizing about 6 draw dies to accomplish the deep draw from blanks that were made from steel about 1/8th inch thick. They were then automatically transferred to a lathe that machined the mounting surface. they then went through a washer followed by an electrostatic paint process. The mounting hardware was then installed followed by silk screening. The filter was then installed, the assembly packed in cardboard half cartons, placed on a pallet, top cover installed and shipped to the engine plant. After 55 years some of the details are blurred!! The plant ( and AC ) are long gone.
                      • Steve C.
                        Infrequent User
                        • June 26, 2012
                        • 28
                        Don, thanks for the info! Very interesting to hear from someone actually involved in the process.
