Sealer used on midyear hardtops between stainless trim and roof panel - NCRS Discussion Boards
  • Jeff H.
    • September 30, 1988
    • 53
    Hello,
    In restoring my '64 hardtop, I removed all the stainless trim and weatherstrips for polishing and replacement. In the process, I made an interesting observation about the sealer used between the stainless trim and the roof panel. There appeared to be two types of sealer applied between all trims pieces and the roof panel. One type appeared to be a black sealer, and the other was a light gray sealer. Both appeared to have been installed at the same time, based on the "squeeze pattern", and were liberally applied side by side. I'm wondering if there was a leakage problem recognized by the factory, and this "belt and suspenders" approach was used to assure a fix. But, why two different materials?? Perhaps one of the sealers was a dealer repair. I doubt that, as the use of dual materials appeared on every piece of stainless trim. A dealer would have typically addressed a particular point of leakage and would not have applied sealer under all trim pieces. Was there a GM service bulletin regarding hardtop leaks issued in that time period? None of this shows for judging, so this is simply an interesting historical observation. Has anyone else out there seen this as well? Any other theories?
    Jeff Hanson
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Sealer used on midyear hardtops between stainless trim and roof panel
    Jeff I think it is all dumb dumb . It comes in two colors , black & white . All the hard tops I have worked on had both colors .
      • 6950
      Jeff you are correct there are two types of sealant used. The light gray I believe can be brought at Home Depot or Lowes(cannot recall the name of the company), the black is still made by 3M its strip caulk.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Jeff, The last '67 HT I restored had the same 2 materials. It must have been their process at Dow Smith.
        You can see remnants of both colored caulking material in this photo to the right on the table.
        There was a substial amount in all areas of the areas where the trims and w/strips were installed.
        Here are some Dow Smith drawings I got from Harry Sadlock. If you PM him he may have more info in his Dow Smith AIM sheets. I can'y find the set he sent me right now.
        Here it talks about sealer X-2719 but I'm unsure what it is.
        Rich
        • Jim S.
          • March 1, 1986
          • 1408
          Jeff,
          You will need a lot of strip caulk !!
          I used the whole box !
          Jim
