c2 rearend crossmember bushing - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 803
    Hello all are the rearend crossmember bushings still available from gm .If so what is the part # thanks for any help Bob
    • 43287
    Re: c2 raerend crossmember bushing
    Bob-------
    If you're referring to the large cushions on each side of the differential crossmember which fit onto the frame "sombrero" brackets, the answer is no. They are discontinued from GM. They are available in reproduction but I question the quality.
    • Michael G.
      • January 1, 1997
      • 1251
      Bob....I've used the repro's with no issue.
      • Bob W.
        • December 1, 1977
        • 803
        Thanks for your replies. You guys are always very helpful. Bob
