65 rear axle U joint outer flange ID & finish - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    My question is two part . (This is part number 51-41 in the long island book) The rear outer universal joint flanges that came off of my 65 BB have a number 3843018 cast into them ( I think they are original ) . I have another set that I think came off a 67??? that do not have any casting numbers but look the same as the 65 pair . I know these are not the early 63 castings I have one of those too . I also have a NOS GM flange that looks completely different and has Spicer cast into it . So what years do I have ? What is correct for a 65 BB. Second question I think these flanges were forged not cast ,if so they should have the darker forged coloring and not the lighter cast blast look . The spicer part finish looks like cast blast .
    • 43248
    Re: 65 rear axle U joint outer flange ID & finish
    Bill------
    The GM #3843018 u-joint flange was used from 1964 through 1974. It may also have been used for very late 1963 and was definitely SERVICE for 1963. This is a forged piece and every one I have seen has had the 3843018 forging number on it. Of course, that does not mean that every one ever made had the number on it. I believe these flanges were of GM internal manufacture.
    For 1975, things changed. Beginning in 1975 the flange was manufactured by Spicer and was of a somewhat different configuration but it was a forged piece, just as the earlier. This flange was GM #360913 and was used at least through 1979. It also became SERVICE for 1963-74 when the 3843018 was discontinued. I don't think the 360913 number appeared on these flanges although it's possible it did on earlier-manufactured examples.
    Tip: the 360913 flange used to be available through Spicer dealers as well as GM and it cost a LOT less from Spicer dealers. It's now discontinued from GM. I don't know if it's still available from Spicer.
    • Carl N.
      • April 30, 1984
      • 592
      Bill
      I have an original and it is marked 3843018 - the 4 and 3 are cut off from the center bore and the "0" is flat on one side - below circle is
      GM 6 ^ looks cast to me but could be forged - these came off of complete rear assembly that I removed from friends car and installed Ford 9" for drag racing. Rear assy had never been apart.
      • Bill W.
        • March 1, 1980
        • 2000
        Hi Carl . Yes thats the same as mine except mine is cast GM 15 A . They all have a forged "ring " when tapped with a wrench . What is the color light or dark ?
          • 43248
          Bill------
          The GM 15A is a forging die number.
            • 43248
            Originally posted by Carl Nicholl (7368)
            Bill
            Carl-------
            All of the 1964-79 u-joint flanges were forged steel. The only cast flange was the 1963-only flange. It had a thicker cross section than the 64-74 or 75-79 flanges.
            • Gary R.
              • April 1, 1989
              • 1799
              Joe,
              Spicer still makes them( Mex). They were back ordered late last summer for a while. Bairs sells a nice flange too, which I believe they have made. I have used both for years and the only problem I had was in my son's 75 when he sheared the spicer solid joints and of course bent the flanges.
              • Carl N.
                • April 30, 1984
                • 592
                Bill,
                I'd call color light - but then that is subjective - what is light to me could be dark to someone else -
