'72 Air conditioner Accumulator/Dryer - NCRS Discussion Boards
  • Charles W.
    • December 28, 2010
    • 41
    I converted the air conditioning system on my '72 to R134late last summer.At that time, Iinstalled a new dry/accumulator. I'm nothappy with the results and want to convert back to R12.Do I need to replace the dryer beforeconverting back to R12?Where can youbuy a dryer for R12?All that I havefound say it is for use with R134.
    Thanks for you help.
    • 43222
    Re: '72 Air conditioner Accumulator/Dryer
    Charles------
    I would definitely replace the accumulator/dryer. Among other reasons, it just doesn't cost that much. Use GM #3046236.
    The real problem is that you may also have to replace other parts such as seals, o-rings, etc. You must remove all of the oil from the system and replace it with the proper oil for R-12.
    • Gary V.
      • April 15, 2012
      • 76
      Charles,
      The dryer will work for either Freon. The system must be completely flushed and cleaned before changing back again.
      Gary
      • Charles W.
        • December 28, 2010
        • 41
        Joe and Gary,
        Thanks for the good advice.
