1968 Correct 7 blade fan and clutch fan - NCRS Discussion Boards
  • Jeff P.
    • 799
    I just stripped the 7 blade fan on my L79 ,350 HP,AC Vert. The part number and date C72 would make me believe this is a 1972 March build fan . The clutch fan fits into my June build but would anyone have the correct part numbers for these two items. Thank you in advance. A great hobby, just when you think everything is correct you have a setback. I keep smiling.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Jeff P.
    • 799
    Re: 1968 Correct 7 blade fan and clutch fan
    Diving in to a lot of threads, I've come to the conclusion that part#. 3888366 is the correct fan for a 68 L79 small block with AC. 5 blades with 5 flat rivets per blade .Now for the markings. H, 66 , front. Would be the only markings. No dates ? Fan clutch would be part # 3916141. CK. With a short water pump. Is there a part number for this water pump. Thanks, Jeff
      • 43258
      Jeff------
      The 5 blade GM #3888366 is the correct fan blade assembly. No 7 blade fans used for 1968. No part number or date code found on the 3888366. Original fan clutch was GM #3937771.
      The waterpump assembly part number would do you no good now. However, it was a GM CASTING # 3782608.
      • Jeff P.
        • 799
        Many thanks, Joe. Water pump is correct . I imagine a previous owner changed the 5 blade to a seven.
        • Jeff P.
          • 799
          Joe,I see that some rivets are raised and some are flat. Was there a difference in 68.
          • Gary B.
            • July 31, 1979
            • 926
            Don't know if this helps or not, but out of an early 69, C02 build date. 10,900 miles, 350 HP with A/C.
            Gary B
              • 43258
              Jeff------
              Rivets seen in Gary B's post are correct for 1968. Also, the fan clutch seen is the correct one for your 68. However, very early 1968 small block with A/C may have used the GM #3916139 fan clutch.
              • Jeff P.
                • 799
                Thank you Gary and Joe. Great pictures.
                • Jeff P.
                  • 799
                  Joe, would there be any markings on a 68 fan such as the word front or a letter?
                    • 43258
                    Jeff-------
                    It will have an "H" and a "66" stamped on the center section. If it has that, it's right. If it doesn't, it's not.
                    • Jeff P.
                      • 799
                      Thank you Joe.
