Ignition switch - NCRS Discussion Boards
Ignition switch
  • Ed P.
    • August 10, 2014
    • 89
    Ignition switch
    Is there something special i should know to take out the ignition switch out of the dash pod ?
    1962
    ed
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Ignition switch
    Nothing special...insert a paper clip into the hole in the switch face and depress the small spring-loaded plunger while turning the switch (with the key in) all the way left...the tumbler mechanism should come out then you can remove the switch bezel with the special ignition tool or needle nose pliers... Have the battery disconnected of course...
    • Ed P.
      • August 10, 2014
      • 89
      Re: Ignition switch
      Thank u Frank
