I'm finishing up working on a 61 corvette and was putting light bulbs in their sockets. The owners manual says the clock should have a 57 bulb but the socket on the clock is to big for the base of the bulb. The bulb kit I have says to put in a 67 bulb. Does anyone know the correct size bulb that should go in the clock? I was wondering if it has the wrong socket end for the clock. Thanks ahead of time for any help.
Clock Bulb Size
Re: Clock Bulb Size
My information says it should be a #67 lamp.I'm finishing up working on a 61 corvette and was putting light bulbs in their sockets. The owners manual says the clock should have a 57 bulb but the socket on the clock is to big for the base of the bulb. The bulb kit I have says to put in a 67 bulb. Does anyone know the correct size bulb that should go in the clock? I was wondering if it has the wrong socket end for the clock. Thanks ahead of time for any help.
DonOThe light at the end of the tunnel has been turned off.- Top
Re: Clock Bulb Size
I have a 60 clock that I just had repaired and I guess I'm in the same boat as David. The Owner's Manual (page 80), says the clock has a #57 bulb, 2 candle power which has a smaller diameter socket. Don, what other reference did you use?
Pete- Top
