Body shims - NCRS Discussion Boards
Body shims
  • William S.
    • March 1, 2002
    • 55
    Body shims
    I have noticed that the C2 body shims are shown with the bent corners turned up in some illustrations and photos and turned down in others. Does it make a difference?
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Body shims
    They should be in the direction of the rubber or aluminum body mount. Other wise the steel of the body will rest on just the four corners-until you tighten them down at which point the shim will bend slightly.
