Correct seat belt bolts for 63?? - NCRS Discussion Boards
  • Donald A.
    • January 7, 2013
    • 239
    I've pulled the trigger on correct seat belts from Charlie at Seatbelt Sity. Would like to use the correct bolts to install.
    Can an someone point me in the right direction. What I had in the car is not correct for sure
    thx
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Correct seat belt bolts for 63??
    Believe mine used "clutch head" bolts. Just one of a few applications that one might buy a set of clutch head sockets and screwdrivers for. Another being Holley metering block screws.
    Stu Fox
    • Donald A.
      • January 7, 2013
      • 239
      Very interesting! I will look in the AIM and other documentation I have. Why would such an odd bolt be used?
      Anyone else verify this question??
      thanks
        • 6950
        Don, the correct bolts for the seat belts are sold by Long Island corvette. they have a rounded head with a allan head.
        • Stuart F.
          • August 31, 1996
          • 4676
          Don;
          Ed is right as far as the Judging Guide states they are Allen head cad or zinc plated round heads. I changed mine out in the 70's to what the guide says while I was upgrading my interior. But, my originals were clutch head and I know I never changed them before then (original car, original owner). I changed them because they were corroded and shabby looking. I still have them in my original parts boxes somewhere. The reason I recalled this is due to the fact I had a heck of a time getting them out and had to make a tool. I've noticed in older cars that clutch heads may be found in "safety related" hardware such as door hinges or seat mounting applications. Why, I don't know except maybe they didn't expect or want back yard mechanics to be messing with them. If the guide says Allen head you should go with that.
          Stu Fox
            • 6950
            Stu, like anything with 63 I learned never say never. all I know is the reproduction guys make the allen head types.
            • Donald A.
              • January 7, 2013
              • 239
              Thanks so much for the education. The ones we took out were this crazy clutch heads and I thought that just couldn't be right. I'll take a pic and post with some details. Maybe I have the right ones all along?
              • Harry S.
                • July 31, 2002
                • 5332
                I just looked at the bolts, I believe are the originals, that I removed from my 63, it's an April car. They are not clutch head.
                Maybe the early bolts are clutch heads, what is you build month, VIN, etc?
                • Donald A.
                  • January 7, 2013
                  • 239
                  Harry, my car is last week in May 63 VIN 15968
                  • Harry S.
                    • July 31, 2002
                    • 5332
                    Thanks, let's see if Stu gives his build date.
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      My build date was July 8th. The position of these bolts in sort of a corner makes them hard to get at to tighten except with a socket head type tool, be it Allen head or clutch head.
                      Stu Fox
                      • Donald A.
                        • January 7, 2013
                        • 239
                        Just got in my belts from Charlie Seat Belt Sity
                        They look great!
                        • Steve M.
                          • June 25, 2013
                          • 28
                          Waiting on the pix of the clutch head bolts. I've never heard of them...
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            Don;
                            They sure look good. May be I'll get my originals done as well (also dark blue).
                            Stu Fox
                            • Michael G.
                              • January 1, 1997
                              • 1251
                              Bolts in my December '63 are the 'original* round headed Allen head. These would be the only type bolts used in the area 63-67 to my knowledge.
